LD Systems DVOX microphone
LevinGuitar
Interesting microphone. Uncommon shape headbasket (for chinese mics at least). Similar somewhat to the SE X1 and the 414.
Nice solid body, the circuit seems a copy of the one used by Rode in their LDC mics. P. Voltage 52v ( 59-6.8v ), low noise and easily removable led (I don't find it annoying). The headbasket assembly is a bit weird but not really bad. The shockmount is a plastic one but nice.
I guess I have to try different capsules to find what matches this kind of headbasket. Any thoughts?
Nice test here: (TLM103, DVOX, 414)
https://www.infomusic.pl/test/36918,ld-systems-dvox-dobry-wybor-do-nagran-wokalnych
Where do you get it from? Could be a nice replacement for faulty Rode mics
two flaws for now: If the base is not tightned really strong to the body there are shielding issues. And the screw to the shockmount metal is not very good, each time I unscrew it there are a lot of residual metallic dust, not sure if it comes from the mic of from the mount, but anyway 100 times more and there will be nothing or nowhere to screw I guess
A bit of magic foam and will leave it that way. Way less bright than a NT1000
