I'm troubleshooting a Marshall JMP1 preamp and have narrowed it down.
The LED's only turn on (light) once in a while when the power is turned on. The entire display is out, although it will work if I touch the 5 volt rail with an oscilloscope probe (the 5 volts looks good and steady).
Refering to the schematic:
The emitters of TR13-20 (MPSA13's) go from CN3 (page 5) to DR1-6 on CN1 (page 6).
Using the diode scale, I measured 1.3 BC, .7 BE and 1.3 CE with similar readings for a few others (transistors were not removed for test).
MPSA13NPN Darlington Transistor This device is designed for applications requiring extremely high Current gain at collector Currents to 1.0A.
I'm wondering if the transistors are all bad in the same way, or if there is something else going on, like a bad regulator (7805).
Any advice would be greatly appreciated!!
Schematics can be found with these links
http://www.drtube.com/marshall.htm (3/4 down the page)
http://www.drtube.com/schematics/marshall/jmp1-61-04.pdf
