Studiogearlover
- Joined
- Mar 14, 2017
- Messages
- 192
Hey Guys..i have a wonderful broadcast mixer (Gentner) from 1989, 4 channels sounds great, got it used... (for 50 bucks). However, there are few little things are going on while I was testing this. I would like your expertise on this. What is happening:
- Mixer turned on, only on channel nr 3 the peak led indicator blinks momentarily, after like 20 minutes the mixer is on. No signal passing. While blinks, no distortion or anything coming out of the mixer. Seems that the peak LED indicator has its own life...
- while switching off, i hear a high sweep ish noise, with a little pop, few of the LED indicators pops up, some in red some in green. Not sure if this is normal or tend to be like this, it seems a bit harsh to me .. not enjoyable when your power amp and speaker is on.
Maybe the two issues above are related to each other? Overall the mixer is super nice... however, the above are bothering me a bit..
In case you had similar issues with any of your audio gear, please share your solutions/problems! Cheers!
