supafuzz99
Member
- Joined
- Nov 26, 2014
- Messages
- 17
Hey I have several Shure mixers with the limiters inside that sound great...what is the difference between those and the Level-Locs???
It seems they're not much different, except the se-30 has a release knob, which the level Loc lacks. I just got myself a se-30, but it's not working right now, so I haven't had the chance to put it up against my level loc yet....supafuzz99 said:Hey I have several Shure mixers with the limiters inside that sound great...what is the difference between those and the Level-Locs???
Hi Vires,
There’s no pcbs available for this project, at least in a standard rack format like I did.
There might be an old project around here for a Level Loc in a 500 series format, I have some recollection of something like that but I don’t remember the name.
Long time ago, before I did this project I bought a PCB of an even older project called the “Sherlock” it was a level loc clone project but it was already dead and buried when I build it. Long story short I was able to buy a PCB of that Sherlock project and as I wanted to do a stereo unit I scanned that PCB and home etched a second one.
So you have 3 options, or you try to find a PCB of the project for the 500 series (if that really existed and it’s not my imagination), or you design your own PCB based on the schematic or you home etch a PCB with scans of an already made pcb (Sherlock)
I’m sure I still have docs somewhere for the Sherlock project. As for the schematics they are easily available and they show where the transformers connect. But if it’s the case that you don’t know how to read a schematic then you should forget doing this there’s no plug and play kit with simple build a puzzle instructions.
The transformers used are 1:10 transformers, you can use any mic input transformer with that ratio. You can also find those transformers in M67 and M68 Shure mixers.
I’m sure I still have a few of those transformers I can spare, let me know if you need them.
You don’t need step down output transformers for this circuit, they’re useless, everyone uses the unbalanced line level output. So just count for input transformer
I can figure out the schematic, for something like this anyway. It’s my first rack mount build will be the harder part…Hi Vires,
if you can share the info/files.
I’ve seen some 500 series versions that look interesting (this one in particular I thought looked cool: Toneloc Level-Loc Compressor Colour
I’d be glad to get the transformers from you if you have extras- kind of you to offer
The one I know of is the Standard Audio Level-Or.It’s not that one, that’s just a module, there was an actual 500 series complete unit
Hi Rémi. Did you end up finding the dimensions for the board? I’m not sure how to accurately scale from the resistor size…That's great man! I'm going to build this right away!!! What size should the pcb be?
Cheers!
Rémi
Hi there - apologies if I'm being especially dense here, but I can't figure out how to scale the board. I understand the length of resistors depends on the power rating of the resistor, and no where in the parts list does it say what power rating (unless I've missed something obvious). So I'm at a loss - of course being more of a beginner with this stuff I'm sure I've overlooked something, so any help is completely appreciatedpcb traces for home etching:
