trashcanman
- Joined
- Jan 26, 2016
- Messages
- 104
I picked up a Lexicon PCM-60 for next to nothing as it was said to have some problems. Opening it up I noticed it was missing the DA convertor IC, which was a slight problem. I found some nice ones on ebay for a few hundred dollars but decided against getting one of those and instead bought one from China for $20, which may be contributing to my problems.
Looking at the datasheet(http://www.datasheetarchive.com/dlmain/Datasheets-8/DSA-156635.pdf) for the PCM53JG-I it seemed to say the only difference between the PCM53JG-I and the PCM53JP-I is that the JG-I is ceramic and the JP-I is plastic. No big deal I thought, and the unit actually does function now with the new IC but the reverb sounds extremely distorted and fuzzy.
I can't find much info on the unit online and at this point would probably pay for a manual if I had to. Could I have bought a crappy IC from China that is not converting properly? Are there any standard test procedures I can run through, is there a hard reset option?
I made a recording of some piano being run through the unit. This is entirely signal as it passes through the unit, with the mix level at 0 to start and then turned up and flicking through the settings. This website made it into a mono file and it might have downgraded the quality but it gives you the general idea.
http://vocaroo.com/i/s0Kdy8VN3lSC
