Hello everyone
I got a PCM42 with the extra memory board. Maximum delay times should be 2400ms in normal mode and 4800ms in 6kHz mode, both with the manual knob set to "x1.5".
If I set the knob to "x0.5" I read correct values which are 800 and 1600. In fact I get 888 and 1700ms respectively. But I can't go higher than 4132ms instead of 4800. I have removed two ICs on the extra memory board (both at the same time and one by one) but still can reach the 4132ms delay time at max.
Any idea about what could be wrong?
Thanks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
