bjoneson
I've had the great pleasure of kicking around ideas with folks here, and finally have a schematic put together for the Input Modules on the summing amp I'd like to build.
Here's some notes:
- I'm building this based in a modular chassis I have a personal attachment to. Each module is about 4.5" x 7.5", and is set up for 44-Pin card edge PCBs. That's why I'm using the 44-Pin format, and the choice of 4 channels per module is because that's as many as I could put front panel controls in for.
- This is a one time, DIY thing for my own personal use. No intention of doing any type of "production" run. As such, I'm not overly concerned about driving down part count or quality.
Here's a basic run-down of the circuit:
- Balanced line receivers from INA2134s (Could have done 134s for better channel separation, or gone with some of the newer THAT designs, but I have a pile of 2134s already sitting around).
- Coupling cap into 10k Pot acting as a "fader"
- GAR2520 (from classic API providing 10dB of available gain at the fader)
- Coupling cap to bus assign module
- Bus assignment is a little nasty looking in the schematic. Each channel has an "L Assign" and "R Assign" DPDT switch. When the L assign switch is engaged, it attenuates the opposite channel by ~3dB (by engaging the additional series resistor) and visa versa. Having 3dB attenuation when both switches are engaged is a "nice to have", as opposed to a hard requirement for me.
I do have a couple of question marks I'm hoping folks would be willing to weigh in on:
- Coupling caps... I know they're needed to block DC. I chose the astronomical size of 470uF because the general advice I've gotten is the larger the better. I'm sure they could be smaller without impact the sonic characteristics of the circuit, but is there any negative impact to using the large values?
- Opamp stability compensation. I've got a 22pF cap in parallel with the feedback on the GAR2520's. Trying to make sure I've got the value correct.
- Bus impedance. I've been reading Doug Self's book, and he seems to be a huge advocate of "Low Impedance" design. That is, using the minimal practical impedance, reducing the level of Johnson Noise, etc... I'm planning on using 4k7 bus resistors in this design. With a total 24 channels. Obviously the bus source impedance is going to be astronomically low in that configuration. Any issue with that?
I'm beginning to lay out the PCB for this module in KiCad, but was hoping to see if there were any thoughts on the circuit itself before I get too far down the rabbit hole.
Many thanks!
-Bob
Here's some notes:
Many thanks!
-Bob
