hi there! just have a quick question i could do with some help - much obliged for any assistance offered...
I'm putting together a passive attenuator out of two 33k resistors with a 150ohm resistor across the two of them (to simulate a 150ohm load to the preamp) so that i can feed line level keys/rhodes etc into my seventh circle N72 neve-type preamp.... i was just wondering if i would get any problems feeding an unbalanced output into this arrangement? i.e the -ve side would be linked to earth.. also wanted to double check the resistor values i'm using would this be suitable for bass guitar/fender rhodes type outputs also? i know i should really use a passive DI box but budget is zero!!
thanks in advance!!
thanks in advance!!
