And on the subject, I did some tests in a typical opamp circuit ..
... of my usual 'lm series regulator' bipolar supply pcb module [+/-17Vdc @ 100mA ] and an 'ebay class-a discrete bipolar regulator' pcb module for same.
I did see a couple of dB improvement in the 'hum floor' using the discrete class A setup.
Not so much really, but in a 'class A audio path' [which was what I was mostly interest in] it did end up between 1 and 2 dB of 'better'.
At higher current levels, say 150mA .. 500mA the difference was more pronounced
ie. circuit under test changed from 'ne5534' chips to 'class A discrete low power' to 'class A discrete moderate power' etc
For a headphone amp circuit, I did find the class-A regulated and class-A audio circuit to be very good performing, but of course at a cost of heat ... both in the regulator (a dc amplifier) and the audio (an ac amplifier) ... for class A all round
Anyway ... something I found interesting last I measured these things ...
