Hi all - been a while... hope all are well and good and happy!
As always, I've drifted into a weird theoretical concept, spent a few solid weeks thinking in my spare time, and just today compiled my thoughts and did some SPICE sims...
This time, I'm on Mic Pre design (opamp based - possibly relates to other approaches too). After much reading I've come to learn a reasonable amount about gain / freq roll off and phase delay within opamps. I thought: "well, I wonder how you can get rid of that" and started my spare-time-thinking... Phase shifts? filters... inverting this; doing that...
The goal - not specifically for sonics, but just out of interest in learning: to see about a developing a super flat mic pre with negligible phase delay...
As is typical, most of my ideas kind of didn't make sense in practice (well - simulated practice), but some were close and I've now developed up something pretty cool actually (I think) - have a few questions though that I'm hoping someone can help me with...?!
I've developed a way to really remove phase delay & freq / gain roll off on the opamps I've looked at (primarily the LT 1115) - take a look at the attachment (scroll right), showing an LTspice AC sim where:
So I'm pretty stoked with this result in theory!
Here's the initial questions:
a) I've now realised that roll off and phase delay for ultra fast opamps (e.g. GHz) is well beyond audio range... But audio Opamps (those toted for use with audio) almost always have phase delay right through to the 100's of Hz and a roll off around 10kHz, often with 3dB drop within hearing spectrum... why aren't audio opamps optimised for gain / freq roll off beyond audio range like GHz opamps are?!.. bound to be a reason?!.. I find the concept of e.g.90 degree phase delay within the audio spectrum pretty odd for an "audio opamp"... Almost a bit sloppy to be honest?!
b) I've also plotted circuit noise - but realised I don't know what I'm looking at??! my design (at a reduced 60dB gain) clocks up "9uV/Hz 1/2" (that's at 1kHz)... I truly don't understand what that means though... I've of course read online and done some math, and used some online calculators etc... But I'm not sure I trust my numbers for use in audio... Is anyone able to assist me in calculating this as a noise floor in dB for line level audio?! and explain it too please!!... and at 60dB gain- is this good or crap as a noise level?!
As always - I really appreciate any insight... Also interested to know if "you always do tricks in a mic pre to combat phase delay & gain/freq issues", or if my results are possibly kinda cool...??!!
- Left axis = gain (solid lines of a given colour);
Right Axis = Phase (dotted line of the same colour);
Bottom axis is freq from 1Hz to 100kHz;
Blue is an example instrumentation Amp (LT 1167);
Red is a single LT 1115 pumped up to 80 dB gain;
Green is my circuit also at around 80dB gain - note the dotted green line at the top is my circuit at roughly zero phase delay, and the solid dB line is basically flat (to within 0.0-something of a dB at least).
