mrtnasty
Anyone ever tried this? Too much distortion?
Thank you, I will try it and report back once I get around to replacing the caps and wiring it up.Tube gains on paper are based on infinite loads, as soon as you put them in real world circuits there’s very little gain difference. Especially with NFB present. Wire it up, try it.
The spec for this mixer says the maximum mic gain available is 108dB. If anything I would think these days you would want to be reducing the gain rather than increasing it.Maybe better to add gain from different trafo ratio(s)?
Thanks!12ax7 would certainly have decreased gain and higher distortion driving the output transformer. Don’t use a load resistance on the output, you’ll have 7dB more gain. Rewire the output for 600 rather than 150. Also more gain.
