Hi
I'm new here and I would like to ask some questions regarding construction of a compressor/limiter based on LM13700 (I have two chips) and easy obtainable low-cost components (NE5532, TL084, BF245/256, BC550...), my finances are limited and would need the circuit as a DAW complement, and make is as fine as possible. I've made up my mind about input/output stages, which seem a bit too much, but I'll use it with computer-card ADAC which is suboptimal (jack-type, balanced), so I read jensen papers on servo I/O circuits and they don't seem cost-prohibitive (won't use transformers).
What I need is a gain-control cell and sidechain circuit with attack/release (maybe autorelease). I suspect the best way to get best performance would be to use 13700 as a "variable resistor" in NE5534(2) feedback path.
I know LM13600/13700 aren't the greatest but 13600 was/is used in "pro" gear (e.g. Tl Audio C1 compressor), and I have seen some limiter schematics (for PA) which use it as a gain controling element in low-noise opamp (NE5534) feedback loop.
I have seen some sidechain circuits here, and there's one below for 13700 (in german - I think the sidechain HPF filter could be easily moded to variable SK topology with additional C5 and dual 1M pot), but I don't know if they could be adapted for use with LM13700 as "variable resistor".
I'd also like to add a "key listen" option, but don't know if CMOS switches are any good for such application - would be LM604 better for audio use?
I have prior discrete audio-building experience, but haven't done anything in last 8+ years.
Please, help !
(some advice, maybe somebody has a good, working schematic to take a look at?)
what I looked at before posting here:
limiter with lm13700:
http://www.elektronik-kompendium.de/public/schaerer/otalim.htm
http://www.elektronik-kompendium.de/public/schaerer/bilder/otalim03.gif
that 4301 control circuits:
http://www.thatcorp.com/datashts/dn115.pdf
http://www.thatcorp.com/datashts/dn118.pdf
http://www.thatcorp.com/datashts/dn125.pdf
(I don't really understand how exactly these sidechains work, but descriptions seem cool to me - I like the looks of dn118 fet circuit)
tl audio c1 (lm13600)
http://www.soundonsound.com/sos/mar99/articles/tlaudio.htm
limiters in power amplifiers:
http://www.yorkville.com/downloads/servman/smcr5.pdf
http://www.ofgb.org/reference/Music/Qsc/Service%20Bulletins/RMX%20service%20manual.pdf
jensen balanced input/output:
http://www.jensen-transformers.com/an/an003.pdf
http://www.jensen-transformers.com/as/as030.pdf
(I would replace LM11 with TL08x and capacitors on output - i.e. w/o transformer)
http://www.jensen-transformers.com/an/ingenaes.pdf
(figure 10 - God knows what comes out of computer card)
Please, help !
