Hi everyone, I hope you're all doing well.
I included a snippet of a schematic that came from here: THATCorp 4315 One Knob Squeezer PDF Link
It's a compressor circuit, and the snippet I provided is where the control voltage gets manipulated.
In my (tiny) brain, the LM334 is basically just an amazing resistor right? It 'sources current' and does it with incredible accuracy so...its an incredible resistor lol right? Why do I feel like I'm gonna get eaten alive for this sentence..
Anyway, in this circuit, very near to the 334 there is a "+VP" and "-VP" as well as an inverting op amp (U5A)...
- Is this small portion of the circuit actually creating a dual supply for the "more" potentiometer VR1? The '+VP' is also used for VR2, but nowhere else. I guess I'm a little confused what VP stands for lol.
- If I'm right (for the first time), and the whole point of this little 334 and surrounding circuitry is to create a dual supply for the purpose of the 'more' control, why not just use a charge pump at the power supply and run everything off of it? It would avoid having to DC bias anything, eliminate the voltage divider and buffer at the power supply...
- Is it because charge pumps (1044, for example) don't supply enough current? Or are unreliable?
The LM2662 could put out up to 200mA, but is 5.5V Max. Still, a 10V span for a small audio signal is quite sufficient...
Perhaps the THAT4315 wouldn't enjoy a dual supply, but for a similar price, the 4305 can. Hmm...
Thanks in advanced! Also, apologies in advanced for any toes I might have somehow stepped on without realizing lol.
