LO1166 issue in 1272
Golgoth
Paris, France
I am having an issue with an LO1166 transformer I am installing in a 1272 module I am restoring.
The output has absolutely no bass. I tried without the zobel components, same thing.
The rest of the module is working well up until pin 1 of the LO1166, but pin 5 & 8 output no bass, the transformer basically acts as an HPF (pin 5 is louder than pin 8 if that is useful info).
What can I test/measure to make sure the transformer is okay? It was provided to me untested by a client.
G
And what're you plugging the output of the transformer / preamp into, that results in "no bass"?
Photos of the connections could potentially help... But i'm starting to wonder if, by some freak occurrence, one of the four windings ended up being connected in reverse, somehow?
Same result with an audio probe and in my 1272 rack.
"With an audio probe"? (Those are rarely balanced-input, but i stand to be corrected...)
And "in my 1272 rack" is not an answer to "what is the output of your 1272 plugged into?" question. Because logic / physics...
here is a print for checking things out like DCR etc
there is a reverse wind on the original that the later versions did not have but that should no affect the terminal assignments but you could try swapping them anyway,
that xfmr did not have a ton of inductance to begin with, steel core, not that many turns, maybe something other than the circuit like test leads, test equipment, etc,
i doubt the gap has increased as those are glued together pretty good.
    82.3 KB
