lionpawsoundsystem
New member
- Joined
- Nov 28, 2015
- Messages
- 2
Good Morning all,
I should start by saying this is my first forray into the circuitry world and, depending on its success, possibly a new side hobby! However consider me a complete newbie. Apologies if this question or any further show my complete lack of knowledge,
I have recently purchased a Roclab3000 delay unit (which I assume will fucntion very similarly to the Boss DE200). Unfortunately, it appears that all of the pots need replacing as they appear to cut in and out when turned.
I have managed to locate and order most of the required pots basic log and linear jobbies but there are two which i cannot track down.
The tag on the pot is T0BM20K YH. It has the standard 3 pins coming off at 6 o clock and an additional pin coming off at 12 o clock and also has a centre tap. Splined Shaft, 16mm long, 6mm diameter. The photo below shows the problem pots, the pots of interest at on the RHS.
Can anyone advise where to find one of these and, if not, whether there are any alternatives which will perform the same function?
Many thanks in advance for all and any assistance.
Peter
Peter
