I need a DC log converter for a level meter project. I found one that I designed a long time ago (made of transistor array and op-amps). It works fine but needs trimming. I thought that there must be available some (laser trimmed?) chip to do the same job but without manual trimming and component selection. It should be non-inverting (lin input 0...x volts/amps produces log output 0...y volts/amps) and provide 80dB range. Any suggestions?
