CJ
I will trade the CRT display for the LCD anyday if the LCD model does all the math. You do not know how time saving those new scopes are til you use one. No more "Let's see, I'm on 5 volts per centimeter, the trace is bouncing from -1.7 cm to plus 1.7 cm after I centered the beam, so thats blah blah blah time 5 = pk to pk , so if I divide by two and then root 2, that gives me blah balh blah RMS. With the new scopes, you can toggle between pk to pk, RMS, mean value, with the push of a button. And it has a built in feq counter so you do not have to do the same calculation for frequency. A transformer sweep test take 100 times longer on an old scope than the new ones, becuase of the cool software.
