So, the french word for direct is direct?
Agreed. I strongly suspect that there will be no room for the inside-the-chassis part of the female connector. If you switch to ANY female XLR, you are probably going to need to make a metal tube/stand-off that keeps the whole connector outside the chassis, so it looks kind of similar to what you have now.I have found that often the female chassis mount connector is to big for the allotted space so they won't fit if you did find them. That might be the case here if you think about it.
Sorry, you wanted to change the XLR3-m to an XLR-3f. I only know these:I'm surprised to hear that Socapex made XLR connectors. Is that proven?
In any case: The closest replacement product is probably the Switchcraft DEP3M:
https://www.switchcraft.com/assets/1/24/DEP3M-DEP7M SERIES_CD.pdf?6614
Nick Salis
That's an old standard at RTF/ORTF.They are the mic inputs on a Girardin mixer. Reverse gender
I can't say better...take half an hour to solder 4 proper XLR cable for the Girardin, keeping the console originalShort answer, get 4 female to female XLR adapters and go with that.
I confirm that, there is lot of room in the MT47/48 for the battery holder at leas 1/3 of the whole volume of the desk, but underneath the faders...the upper section is too busy.I strongly suspect that there will be no room for the inside-the-chassis
According to the 60' service manual/part list, those 4 connectors as the one for -reprise- (single AUX output on MT47 or 4 direct OUT on MT48) are branded Socapex.I'm surprised to hear that Socapex made XLR connectors. Is that proven?
