Hey guys,
So I spent a lot of last year reading about electronics but I’ve only just recently started getting my hands dirty.
Purely out of curiosity (and because I thought it would be fairly simple to pull off) I want to see what it sounds like when you send a signal through a transformer that’s much hotter than it’s rated for. I was originally trying to keep things passive but it seems like I’m going to need to buffer the signal coming in. I’m using it with my Eurorack which has a typical output impedance of 1k ohms.
I just wanted to share the schematic on here to see if anyone can spot anything clearly wrong with my design or has any suggestions.
The idea is pretty simple, the op amps are there to buffer the signal going into the transformers. Running straight into T2 should keep things at unity gain but there is a switch to send the signal through T1 adding (I think?) +18db, the potentiometer at the end is there to tame the output level if needed. I’ll probably power the circuit with a couple of 9v batteries for now.
I’m unsure if the components in the feedback loops of the op amps are necessary since I’ll just be using them as buffers for now (I was repurposing part of a boost pedal schematic for this ). I may add a gain control on the first op amp later down the line though.
Edit: I seem to have a habit of wiring the jacks wrong on KiCad
