Very rough but I guessed fleshed out a bit it could look something like this? RV1 = input level, RV2 = Bias control.
Sam,
You need to learn more basic electronics. I do not now have the time to teach you.
I can do a masterclass on this kind of circuit, including showing how derive operating conditions and calculate all parts of the circuit as well as to how simulate it in a few weeks.
I am attaching a commercial but discontinued design of mine, that is a "perfected" RPA. It was actually actually was quite liked by some studio people. Especially in the final mastering step.
Several 1,000 were made and sold and it's reliable. A review that describes the function is here:
iFi iTube Review
The "FX" is a version of Phaedrus "FRANCINSTIEN" (plus some extra) and the Taddeo "Digital Antidote II" respectively.
I apologise for the way it is drawn, which does not make the circuit easily to understand, I thought I had a file from TINA, but alas no. This schematic is for PCB design and the full product.
Here is a photo of the actual PCB:
You can see it is quite SMD part heavy.
The current through the tube is equal to the bias of the 2N4403 (MMBT4403 is the SMD version), so the tube operates in "starved anode" mode (~ 24V/0.1mA). Big advantage, extremely long life and ton's of harmonics. The second "advantage" was not one for "HiFI" use and the later version dropped HD a lot and used a much higher anode voltage and current.
The Mosfet can be replaced by IRF710 or similar without other change. Design center is 3V Vth which equates to 4mA in the 2N4403. The Mosfet follower at the output runs at ~10mA so max output into 600 Ohm is only 4.2V (+14dBU)
The follow-up version made a number of other changes. The PNP Transistor was replaced by a P-Channel Mosfet, the positive supply was raised to 48V from 24V, the current source NPN was replaced with Mosfet and most crucially a DC servo was added to eliminate the output capacitor and also the capacitors in the feedback loop. It is also a lot more complex and not really suited to DIY.
Should anyone wish to produce a commercial product based on this, I suggest to contact me for the updated version and other changes and naturally a licencing agreement. I can also help apply the same principle to other products (e.g. Microphone Pre etc.).
The circuit posted here is completely depreciated and outdated and not recommend for mass production, but it is suitable for DIY assembly, once the SMD parts are replaced by TH parts.
I would still roll in some of the updates I applied to the later version and rearrange the feedback loop to include the coupling Cap and feedback DC blocking Cap.
We will do all of this in the masterclass.
Thor
