looking for opamp ic's that run off +/-24V
pucho812
third stone from the sun
o.k. So outside of the opa604 and it's dual channel counterpart the opa2604 I can't seem to find any opamp that runs off +/-24VDC I am sure there are others I just can't find any or know of any. Are there any outside of making  doa's?
Hi, ±22V is more common, anyway with this you can make any opamp work at this rails or even higher, just with 2 trans and 4 resistors, I've seen replace 2 resistros from output to bases with zenners but not necesary...
http://www.picstopin.com/1607/-reference-requirement-and-resulting-common-mode-limitation-was-made/http:%7C%7Cwww*ka-electronics*com%7CDC_Preamp%7CEDNIFD04261974*jpg/
JS
JS
your like is 404. Most common for chips is +/-18VDC or 36V supply voltage
gyraf said:
Some of the new power amp chips?
maybe but searches on both ti and analog devices yield nothing other then the opa604 and dual channel version 2604 listed above
pucho812 said:
I still need to get doen to your warehouse apex jr.  As much as I would like to experiment need parts currently manufactured and fairly easily available.
Just give me a call and we can set it up...
I just looked and have a good quantity of a + - 22V  NE 5532N at .39 ea and $35.00/100 pieces if your interested
Spec's here...  http://pdf1.alldatasheet.com/datasheet-pdf/view/54235/FAIRCHILD/NE5532N.html
