For a bit of fun I’ve been putting together a spreadsheet that contains different formulas I might find useful when designing an Audio Power Amp circuit.
The output for the application I had in mind is fairly low (3-5W with 8ohm load). Some of the ICs suited for this have quite a large minimum gain (20-34db). If the input voltage was line level (+4dbu or 1.228 Vrms) I would need to attenuate the voltage before amplifying it to get the desired output. I would also like control over the input volume.
I was trying to work out how I might approach this, I thought it would work if instead of having a voltage divider then a potentiometer I could put a resistor in series with the input of the pot to effectively set the minimum attenuation the pot applied?
The equation I’ve used to worked out the value of this resistor is R1 = R2/(((10^(A/20))*R2)+R2)*R2 .
Where R1 = the value of the resistor in series with the pot. R2 = that overall resistance of the pot. And A = the desired attenuation in DB.
Would appreciate if anyone could verify if this is giving me the answer I’m looking for. Seems about right to me. Sorry if this equations is clunky it’s just what I ended up with
