OK, but according to the voltages on g2 and anode, R5 (g2) draws 0.11mA and R6 (most of plate current) draws 0.46mA. Where is the difference going to?moamps said:@Abby
The voltage drop on R18 (47k) is 50V so I think that 1mA for first tube's cathode current is a good assumption.
I agree that in later measurements first and second kirchhoffs are not so happy.
rock soderstrom said:Thanks Eric! The "Frag Jan zuerst - ask Jan first" labeled PSU capacitors are funny! ;D
Shouldn't the wire coming from the common connection of the gain RC circuits be shielded too? If not, what's the point in shielding the cathode? Unless it is inadvertantly, just a consequence of proximity to the sensitive grid area...Ericbazaar said:C3 (25nF), W1 (2M) and W4 (1,6K) for the EF86 Tube. These three Components are shielded too with a little Hood.
Ericbazaar said:, these are made by "Fischer & Tausche" Germany i think.
Ericbazaar said:These are the Modifications i've found in booth units. Eckehard Dux (a german specialist for tube Gear) told me, this was a standard Mod in the DDR for HF Freq Blocking. Hmm, not shure if its right...
Ericbazaar said:It works and sounds really good, but this is a prototype! i build in other Transformers with lower Ratios, so the Workpoints of the Tubes musst be changed. i tested different settings in the last weeks, i am soon on target.
rock soderstrom said:Saugeil!!! What kind of transformers and inductor did you use for that build?
What is the equivalent us term - rear ended??PRR said:> to hit the car directly in front of you
Not used that way in America.
