Low filament Voltages
Johnny1234
Dupont, PA
How I am just finishing the final touches the Dave P mix buss compressor. With my lights hooked up my filament voltages are about 10% low. Don't want to use led lamps as this piece is so cool. How much harm if any is this?
Many Thanks John
https://groupdiy.com/threads/reduced-filament-voltage.32746/
Iow you might have to try by yourself to see if it makes a difference. That said 10% is not a lot and some brands just run their tubes at 5,7v in commercial offer and nobody ever complained on the longer lifespan of tubes.
I don't know the tubes Dave used so can't comment more on them. Maybe there will be a difference on the varimu tube of the circuit idk? But you should not destroy anything in a test.
