Thanks for the interesting link (I happened to be looking for a differential limiter), but I don't see how it has a bearing on this thread. The original poster said he wanted to divide down (which is one of the few sane ways to get a low noise derivative clock), and I pointed out that 24.576MHz can't be divided into 44k1. PLLs, classical or not, weren't mentioned anywhere.
If, like the original poster, you're looking for a low noise master clock, I would strongly recommend staying away from any kind of PLL. The base system noise of most phase comparators is much worse than what you can achieve with a good high-Q crystal tank. Besides, what are you going to use as a reference clock ? If you happen to have a low-noise ref clock design, why not use it for the sampling clock you were interested in in the first place ?
JDB
[who realises that, in a studio, one might need a PLL to lock to word clock. Just keep in mind that, with a good free-running Xtal oscillator, that will likely raise your clock jitter]
