I know this topic is getting oldish, but I traded some PMs with WO'B aka John Hinson yesterday, specifically about the schemo he drew up of the 610. I put the schemo in the group email account (see META META), along with most of this post.
There is a bit of history first, then some input trafo talk, then some interesting comments on the output trafo. (Either use an output cap or a gapped trafo is the answer, but I admit I got a bit lost with the inductance talk.)
Hopefully this will help someone here :
(the lines are there to separate PMs.)
____________________________________________________________________
The schematic you have is one I drew up from two original 1960's era 610 modules - one from Neil Young's old desk and the other that belonged to Bill Putnam. If you build a unit from that schematic, you'll have a better pre than any current UA reissue. When I did the design work for UA on the re-issue 2-610, M610 etc, there were budget and other constraints that made it not quite what I would have done had I been given a free hand.
Hope that helps Smiley
_____________________________________________________________________
____
« You have forwarded or responded to this message. »
Quote from: mitsos on April 16, 2009, 07:28:52 pm
I did a bit of searching and found there are both Cinemag (CMMI-7C) and Altran input trafos used.
You're talking about in the UA re-issues then. In the old 610's, a UTC O-1 was used.
The Cinemag doesn't have dual primaries but does have a tap on the winding for a lower impedance. It can be used for 200 ohm sources or 50 ohm sources. I don't know the Altran but if you don't need or want the option of the dual input Z then, no, it doesn't matter.
____
btw, is the Cinemag also used in the REDD47?
I used it myself in about 100 that were built. I also used a different transformer in a few special units.
____
Also, Ed Anderson recommended two different output trafos (both Cinemag) CM-9661A if I use an output cap, and CMO-30/600 if I don't. Is there an advantage to either one in this circuit?
If you're building from the schematic I drew rather than trying to build one like a re-issue, the issue at hand is one of there being about 7mA of current through the transformer primary.
You need to know the inductance of the primary at the current flowing through it to determine your low end limit. Inductance drops when current flows through the winding. You figure this low end limit out by knowing the source impedance coming from the tube plate and knowing the inductance of the transformer at the standing current.
The 9661 won't explode if you use it to load the plate - in other words, don't cap couple to it - but you would want to check what's happening at the low end.
If you do use a cap to block the DC from the primary (to avoid current flowing through it and thus not dealing with a lowering of inductance) then you will loose headroom if you are then loading the plate before it with a resistor. Unless, that is, you raise the H.T. for that tube plate (not the whole amp) by about a factor of 2. If you "impedance couple" with a choke loading the plate then you won't loose headroom. You just need to, again, make sure the choke has sufficient inductance for the impedance in hand.
I haven't used the CMO-30/600 but if it has a gap and the inductance is at least 60 Hy with 7mA, then it will work in the circuit.
p.s. the thought occurs to me that there may be others who are thinking of building a 610. Maybe you could copy and paste this somewhere in a thread if you think it might be useful
Yes, it's OK to post the schematic. I think the reason it was hard to find for a while was that I had switched servers at some point and had neglected to update links etc. If it's on your server then it's your responsibility then and not mine Wink
Maybe just give me a credit for drawing it but, either way. it's good,
John
