Thanks Rob,Rob Flinn said:It's probably going into thermal shutdown. How much voltage is across it input pin to output pin ? The more voltage that is across it the hotter it gets and the less current it can deliver. Looks at the data sheet there is a graph for this phenomenon.
I'm getting 5vdc on input pin, output pin is grounded per circuit. The data shows up to 10vdc differential from input to output, if I'm reading it correctly. I'm using an Antek 2215 for the heater circuit. https://www.antekinc.com/content/AS-2215.pdf
