Pliplo said:Awesome, thanks! And should i cut the trace between C4 and C8 and do the solder joint like the pictures?
Pliplo said:Also, im a little lost, i dont have a 220pF for c31 or 1uF poliester in the kit... all i got left is 2 ceramics labeled 47 and 27 and a little blue one labeled 271... Is any of these ok or should i go get what the bom says?
Pliplo said:Finished my build, pretty straightfoward. Got a sweet bass drum sound with a B52 and tested it on a guitar cab with great results also. Gonna test bass DI on saturday's session
your version does not need this mod. This mod is only for the second version's PCBWinetree said:A while ago I built 4 of these pres. Must have been some of the first 8 released.
"yes, you should cut the trace between C4 and C8 and do the solder joint like the pictures.
this joint has the function to connect the ground plane to star ground."
sr1200 said:Got my boards!
Question regarding C6 and C3 the BOM says 470u 25v the caps that were sent are 16v. I have some Nichicon 470u 35v's left over from a previous project. Should I use the 35v or are the 16v caps that were in the box ok?
Thanks! Cant wait to get these running! Classic API is out of the input transformer at the moment, but should have them back by next week.
