MANLEY VOXBOX compressor doesn't work
YannLu
Belgium
Hi there,
I have here a Manley Voxbox for repair.
The compressor doesn't work no matter the position of the comp bypass switch.
Without the schematics, where should I look at first ?
Thank you for your help.
Yann
www.yannluaudio.com
You sure?
Voxbox compressor only acts on the mic/instrument-preamp input, so that insert-rerturn and line-direct can't be compressed. There's a signal flow diagram in the user's manual for reference.
Other than that, look for and verify the +/-15V power supply lines for the sidechain control opamps, IC1,2 and 3 that controls the led in the VTL5C2 opto placed at the input of first preamplifier stage.
Jakob E.
I guess there is a problem with the IC3B because there is a very low signal (20mV) on  the PIN 1 (compressor attack in).
Am I correct ?
Problem solved : I replaced the TL074 in the compressor section and it is working now :)
