yes that transformer does growl and shake the chassis upon startup,
there is a Classic Tone OPT that someone stuck in there, the amp blew a 4 amp slo blo at full power, wtf?
red and wht wires were swapped, amp should have hi-freq oscillated but did not,
switch the wires and no more fuse problems, customer wanted to know why he was going through power tubes so fast, now he knows,
took some readings off the OPT, leakage inductance changes depending on which speaker tap you short out, 16 ohm tap shorted = lowest leakage, often wondered why using the 16 ohm tap sounds slightly better, more hi end due to less leakage, 4 and 8 ohm taps means unused chunks of copper sitting there, >
