MidnightArrakis
[ALPHA -- SR10010F-0204-20F0B-C7-N-0027] -- See below:Yes, they are directly on opposite sides of the board. I didn’t go so far as to check if the footprints overlap (yet). They might need to be offset. The layout was all preliminary - like I said before, just a POC. I have done this with other project before, and while it is a pain, it can be done…as long as you solder the correct side first!
These are the rotary switches I spec’d. I used them once before and they seemed fine: https://www.mouser.com/ProductDetail/Alpha-Taiwan/SR10010F-0204-20F0B-C7-N-0027?qs=8%2Br4Hz5Xir/fy%2Bqxa0GVpg==
>> Have you determined what your PCB-outline dimensions are yet? If so, can you let me know what they are??? THANKS!!!.....
