ksor
I have always had this problem with my guitar amp - it is way too loud when using it in my living room !
I can't adjust the MASTER and the VOLUMEN down LOW enough for using it in my living room - on stage it's just cracked up and working fine.
There are lots of videos/links out there showing the problem and different fixes BUT ...
nearly ALL of them mentiones that the amp has LINEAR potmeters and a switch to LOGARITMIC potmeters should cure the problem - maybe that's correct BUT...
Today I was confirmed from a Fender repair store that the Blues Deluxe allready IS fitted with LOG potmeters !
Now I'm confused - OK, as some mentiones too - some amps was fitted with LIN pots as a failure and MAYBE mine is from a production run in the late 1990's where this COULD be the case.
I looked at the pots in my amp and they have this stamped on them:
MASTER : 10A1M9422 (in the schematic it's R21)
VOLUMEN : 15A250K9448 (in the schematic it's R7)
The last 4 digits is production year/week, I think.
The 1M and 250K is the ohm value, I think.
Then MAYBE the 10A and 15A could tell IF it a LIN or LOG-type - but they can't be the same type LIN or LOG, and I have the problem on both of them.
It's a little hard to take the pots out to do some measuring on them.
Anyone here knowing the meaning of the 10A and 15A ?
Maybe know a fix for that problem with the Fender Blues Deluxe amp ?
