substitute
Hey everyone, I'm working on racking some MCI 500 modules, I also have the original output iron from the mother board. It's going pretty well so far, but I have a question about phase and the OT. I'm taking my output from the line out.
https://www.dropbox.com/sh/2cuxpxiuprace4c/AAB6zmfOGL8krJUVuqgfDId4a/JH500c%2010-25%20-%20MotherBoard%20Mid.pdf
It looks like what would normally be the +, hi, or pin 2 connection is grounded on the primary side while the -, lo, or pin 3 connection feeds the OT. This seems backwards to me, it's not that I don't trust MCI, could some one explain this a bit? Now on the OT's themselves there's not much in the way of labeling, I know they're 600:600 so I guess it doesn't matter.
Now, this afternoon, I hadn't yet seen the above diagram, I hooked up the OT with a 1k pot after it like the schematic Jeff posted here...
http://groupdiy.com/index.php?topic=31472.0
It "worked", but I'm confused a bit as to how. For starters, how exactly does the API output attenuator work? It seems like it blends the out of phase signals together to achieve it's attenuation, right?
Secondly, with the output volume all the way up, I noticed the signal is only on pin 3 of the XLR connector I have wired up, this doesn't seem right.
Can anyone shed some light on how to wire this up so the phase is correct?
