They do sound good , but on an old MCI, there is a problem with the Deck Plate warping if stored in a cold warehouse or garage(think 0 degrees and below). The alignment on that machine references to a thick Flat metal Plate not a cast assembly like an Ampex or Studer. If that plate is warped you will have a terrible time getting the rollers ,idlers and motors, capstan and heads to be perpendicular to the plate. The tape will not track on the head right. Just something to look at. However, that said, I would see if I could get it running. There are plenty of manuals around and some parts I'm sure.
