pvision
Meanwell makes a triple-output switched-mode power supply that might make a good standard supply for low-power audio builds if you don't want to build a linear supply. They are CE-approved and give ± 15v and +5 volts. Standard output connector is a 5-pin DIN and the unit uses an IEC power cable. Input voltage is 90-264 VAC
There are Class 1 and Class 2 versions available. I'm not sure of the differences but suspect they are to do with electrical standards
https://www.meanwell.co.uk/media/productPDF/P25A-T-SPEC.PDF
https://www.meanwell.co.uk/p25a14e-r1b.html#horizontalTab1
https://www.mouser.co.uk/new/meanwell/mean-well-gp25a-gp25b-gp50a/
https://www.mouser.co.uk/ProductDetail/709-GP25A14E-R1B
Nick Froome
Nick Froome
