Looking at the 6N5P (au7 type, mu low-med at 27) 'common plate mix' setup ...
Sig gen remains at 1KHz, 2Vpp to grids
- input to one grid only : the summed plates' THD+N 8.19% at 40Vpp nearly all H2, virtually no hum
- input to other grid only: " THD+N 8.73% " " "
So, not much good from a point of view of low THD
Very little hum, which is good considering there is 2 inputs and plate resistors of only 27K (low gain setup).
However, if H2 is one's thing, then these are good! I 'm trying for lower THD for the moment, so goodby 6N5P :'(
The russian types have a heater difference with the usual a_7 types : paralled heater pins 4,5 with 9 as shield, not center-tap.
I'll try some other russians first, and then other same pinout types I have, even though they are a bit different.
- the 6BZ7 (low-med mu), 6GU7 (low-med mu), 6922 (low-med mu) even though they are all a bit different
First the 6BZ7 - always liked this tube and it kicked off my av7 'thing' - it has a low-med mu of 33 (vs 41 for av7)
tube nbr 1 :
THD 4.06% THD+N 4.06% at 38.3Vpp output, nearly all H2
That's pretty reasonable, around 1/2 THD of the 6N5P at a a little less output voltage, despite it's higher mu.
6BZ7 tube nbr 2 :
THD 3.63% at 31.3Vpp output, nearly all H2
So 20% reduction of output level and a little less THD.
Overall this one is a big improvement over 6N5P
- 6N1P (low-med mu of 33)
tube nbr 1 :
THD 2.77% for 37.4Vpp nearly all H2
tube nbr 2:
THD 2.41% for 37.9Vpp nearly all H2
So a halving again of THD over previous best 6BZ7 and quite consistent (sample size 2
So far, this is the best.
- eh 6922 ( mu 33), a current issue of a tube well known for hifi
tube nbr 1:
THD 1.48% THD+N 1.48% at 38.2Vpp output almost completely H2
tube nbr 2:
THD 1.75% THD+N 1.75% at 38.0Vpp output almost completely H2 - triode #1
1.33% 1.33% 38.1Vpp " " - triode #2
tube nbr 3:
THD 1.57% THD+N 1.57% at 37.9Vpp output almost completely H2
Another eh tube with *really* low THD in this setup. Tight spread for this tube sample size of 3.
I'm keeping the two best for use in my latest limiter build and the worst on I keep in this amp.
So there it is - for low THD the 6922 is the clear winner with the 6N1P as a very close second. Selection from a larger sample size would probably equalise that narrow gap.
And this is at 1KHz only - the story is much more involving when looking at the spectral distribution of thd.
I'm pretty sure the 6922 and 6N1P will remain on top when looking at the low end in more detail.
I'll leave that to when I've eliminated the 'outriders' and settled the configuration of toobs
Anyway, no real surprises here - generally speaking, lower mu tubes of the 'au7' type (mu 17) have a higher THD than low-med tubes (mu 33) and higher, at least in this kind of non-optimal testing.
I *was *surprised by the magnitude of the increase though - 6x higher
in some cases.
Also, the eh6922 tube I selected has a triode #2 with a quite close match to triode #1 - a good sign.
tube nbr 1 :
6BZ7 tube nbr 2 :
tube nbr 1 :
tube nbr 2:
tube nbr 1:
tube nbr 2:
tube nbr 3:
