Melcor 1731 Teardown
hfe depends on current level used, what was the current used for getting hfe = 75?
That is a good question. On all the transistors, I desoldered them from the board and popped them into a cheap tester, which I think runs a couple of different tests and reports the highest value of hFE it finds. At this point there are so many loose parts that it's probably easier to find the bad part by breadboarding the whole thing.
It's soft like silicone sealant, so you just carefully scrape it away.
Exactly. I used a blade to slice away a lot of it, sometimes like carving up a cake. Then poked & scraped a lot of the tiny bits. It does take a long time.
