I have an XRI systems XR330 mtc smpte code unit.
It has a small green Varta memory back up battery, which I think is the type that gets charges up in circuit. The only markings it has on it are "Varta 044". It looks like the battery has 2 cells, & it has 3 PCB pins to solder it in place.
It needs replacing & I`m trying to work out which one to replace it, but the catalogues I have seem to have different code numbers, so I`m not sure what voltage, mAh I need.
From its dimensions the replacements seem to indicate that it is 2.4v @ 8mAh. Does this seem reasonable ?? Or does anyone have a code that would indicate that this would be the case ?
