Metal work for 500 series
Are you thinking of the L bracket specifically? Frank at frontpanels.de can make them for you with whatever drills/cuts you want, and I believe CAPI also offers un-drilled L brackets for DIY (drill it yourself!). As for front panels, of course, you would get those done for 500 series just like a 19" unit, but using the format's dimensions.
both actually. But that is a good bit of information. thank you
If you are going to NAMM there are usually a couple booths of metal fab to talk to.
And MD&M West will be in Anaheim a couple weeks after. Lots of shops there, some that will do 100 pcs. Others will assume you mean 100k when you say 100.
So a lot depends on quantities needed. For a few faceplates it is often easier and cheaper to use front panel express.
I would second Front Panel Express for small quantities, their software is decent enough for most needs, and they can cut, drill, engrave and print.
