Hi guys. Meyer makes a five band per channel full parametric equalizer with plugin boards.
http://www.meyersound.com/pdf/products/electronics/cp-10s_oi.pdf
I have a line on one used for $400 and I really don't think I should pass it up. The pots are all on screwdriver trims (which is ideal for my purposes). The circuitry is reportedly very nice. Each band is on a plugin card (nice). But I want to use it as a subwoofer equalizer (in stereo, two subs) and the only two bands that are relevant are 20-200 and 60-600. Meyer will not issue schematics. I can follow a parametric schematic (barely) but not well enough to mod it without some help and you guys have been terrific. What do you think the chances are that it can be modified for each band to cover 20-200? Worst come to worse, if I cite some values and compare the components here on Prodigy do you think we can psyche it out enough to mod it without an official schematic? I'm betting each board has the same PCB layout and only some of the component values are changed so it ought to be pretty basic substitution.
