Why don't you test at what polarization voltage the diaphragm of the Arienne K47f capsule collapses? Then tell us.Do some of you tested max voltage on Ari K47 Flat ? Mine is in a t.bone SC1100 which can provide (only) ~56v.
In another SC1100 but tubed the AliExpress K47 is fed by 68v and I fear to go much above that (i would stay below 80v). I set a pad by reducing this polar voltage from 68v to 38v and loose about 10dB
Why Arienne doesn't announce the voltage range to not pass over ? It's not for the customer to make that kind of damaging test...Why don't you test at what polarization voltage the diaphragm of the Arienne K47f capsule collapses? Then tell us.![]()
No manufacturer specifies the voltage at which a capsule collapses. It is not of great interest, we all want as much headroom as possible, so do not exaggerate with polarization voltage. Good SNR is obtained from optimizing the electronic circuit.Why Arienne doesn't announce the voltage range to not pass over ? It's not for the customer to make that kind of damaging test...
