[quote author="wilebee"]My 602-2's has small BEYERS input transformers in the front next to the meter about the of a dime in diamiter the socket was for a bridging input transformer Wil
Wilebee[/quote]
Hey Wil, the 602 is the same circuit as the PR-10 recorder. A UTC A-10 is essentially what the input for the 600 and 601 would call for. Your Beyer was the same thing found in the MX-10 and 35 mixers, saturates if you look at it the wrong way. Nobody mic'd close back then.
E.F.: you pick off the mic pre at the record level pot, eliminate the head amplifier, wire in an output like the UTC a-25. If you're humming at the output jack to your board you might try terminating the line. But the siganl going to what would have been the heads is the signal you want, not the monitor signal--the output jack's supposed to plug into a 620 suitcase amp, that what it was built to do. Use the play head signal as DI, etc etc. Already mentioned the headphone jack which you can also succesfully use as an output to a consumer hi-fi input. Have you recapped the power supply in this thing? Trash those multisection caps and check the dropping resistors for spec. If you're pulling tubes and chopping out circuits you're going to have to rework the psu to provide correct plate voltages at the tubes that are left over.
That 6F5 can be noisy too, that's why Ampex stopped making these, they couldn't get low noise ones from RCA anymore, jammed the PR10 circuit in the chassis and called it the 602, last gasp before the AG600.
Personally I think it's a waste of space to use that chassis if you're just going to run one circuit. Yank all that crap out of there, put the tube sockets on the back of a 2U box; if you ever get hold of another one you could probably run two pre's out of one 2U box. You probably have enough juice to roll two circuits from that psu anyway. Sell the meter on eBay, make some money, pull the Ampex tag off the front and make a tie clip.
I'm kind of sick of all these ancient rack whores, they take up too much room. I just gutted my remaining 960's and I'm trying to get 4 circuits in a 3U box times 2. Better circuit than the 600's anyway, same as the 351 without the iron, built for dynamic mikes and consumer hifi line levels. Get CJ to spin a bunch of HA100X's and get the output iron from Sowter, ta-da. Nobody's supposed to be rummaging around in the control room anyway so who cares if there's a wall of Ampex tape amplifiers in there or not.
