I suspect many of the typical solid state "cohen" topology preamps could already do 100 kHz by opening up existing LPF roll offs.kambo said:any mic pre recommendations for recording over 20khz up to 100khz, or any suggestions to record
over 20khz
JohnRoberts said:I suspect many of the typical solid state "cohen" topology preamps could already do 100 kHz by opening up existing LPF roll offs.
The THAT corp 1510 IC specs a small signal -3dB of 3 MHz at 60 dB gain... less gain will deliver an even higher half power point.
100 kHz should not be heavy lifting for a decent solid state preamp, but be careful to remove intentional LPF poles from the design.
thank you!PRR said:The microphone is more a limit than the preamp. Easy to find transistors good for MHz. But microphones must compromise sensitivity against bandwidth. A "speech/music" microphone usually falls off bad above 20KHz. Measurement mikes come in several ranges, lower sensitivity in exchange for flat response to 100KHz and beyond.
over 20khz
moamps said:BK 4135 + modified (without input transformer) Great River MP2 8)
cyrano said:Have a look at Dodotronic. They sell mics, preamps and ADCs for biology:
https://www.dodotronic.com/?v=2a47ad90f2ae
Not terribly expensive. Most others I came across are at least ten times the price, while adding little in features.
I used it for ultrasound measurement and for check some friend's Tannoy super tweeters . Right now I'm working on a design of stereo recording setup for live concerts recording with these microphones, among others.kambo said:heard about BK 4135 mic... cant seem to find enough info about it! any direction !
moamps said:I used it for ultrasound measurement and for check some friend's Tannoy super tweeters . Right now I'm working on a design of stereo recording setup for live concerts recording with these microphones, among others.
Datasheet is here
https://www.bksv.com/media/doc/Bp0100.pdf
This guy uses it for live concerts recording.
http://www.metaxas.com/recordings.html
Pip said:Just out of curiosity what are you gathering the audio to? DAW or other?
The entire signal chain has issue in the equation. Most digital systems will not be able to gather much above 21K . Certain analogue storage systems can like even vinyl, but once you get over a certain point the frequency fall off is real.
I remember reading an article about Sanken C-100 mics being recorded at high speed and then the recording being played back at normal 30ips and the sounds being used in ambient sound design for film. Can't remember what they were using to gather the audio though.
http://www.sanken-mic.com/en/product/product.cfm/3.1000400
4135 is only 1/8" capsule, polarization is 200V. You need also a preamp/impedance converter and a power supply for both. Then you can connect it to a preamp.kambo said:i cant find info re mics its pinout/connections requirements : 100v - 20v etc connections, how much m amp etc pulling...
there is always one on ebay without the connector box, whatever that box is!
PRR said:...But microphones must compromise sensitivity against bandwidth. A "speech/music" microphone usually falls off bad above 20KHz. Measurement mikes come in several ranges, lower sensitivity in exchange for flat response to 100KHz and beyond.
Also, what PRR didn't say but is implied in his comment, is that the larger the diameter of the capsule, the more (acoustically) sensitive it is and so the better S/N, but going against this is the fact that a larger diameter capsule becomes more "beaming" at higher frequencies (much like a tweeter becomes more beaming as frequency goes up). This is detrimental to off-axis response, and gets worse going into ultrasonic frequencies.Tubetec said:...the sensitivity of the system is proportional to the diameter of the capsule as PRR said so your probably going to end up struggling against noise if quiet things you trying to capture .
