leswatts
My latest mics use pol voltage reduction pads (at Ricardo's reccomendation). It's more about totally silent pad switching than distortion though.
I was not willing to have the noise penaltly of bleeder resistors, and even with them a pop is not completely eliminated...because real capacitors have memory...in other words they are (poor) electrets. I came to this decision after having a musician damn near blow out
his PA switching in a cap pad at a live event with one of my prototypes. Just saying "don't do that" was not a solution for me.
I had very little response change with the different polarization levels, but that depends on the capsule parameters. It can be very little or a lot.
On the distortion...This has been long known...probably since Wente in the 1920s. It happens.
If one goes through the numbers it can be seen that stray capacitance induced distortion goes up rather gradually...
really the biggest change is the first 10-20% of capsule active capacitance. A large pad doesn't increase it so much more.
Perhaps a few percent at very high levels. Both even and odd harmonics are present, but it's mostly second and third harmonics.
Typically 90%+ is second harmonic. One could argue that it actually gives a desireable sound color. One could also argue that
at reasonable SPL(say < 100dB) the distortion is inaudible. But we don't switch the pad in at reasonable SPL do we?
Les
L M Watts Technology
Les
