I just purchased these vintage GE 6L6GC tubes from eBay and had them installed by my tech with 40+ years of experience working strictly with tube amps. They seem to be microphonic, at least 3 of the 4, one is probably an acceptable level, but what do you think?
The seller is claiming this is a normal amount of microphonism for a 60's Fender tube amp (mine is a '66 Twin), which may be true? But he's also saying the tubes could've been damaged in shipping, or by my tech, so he seems(?) to also be acknowledging there's an issue here. I've certainly heard tubes that are more microphonic, but the vast majority of tubes I've heard are far LESS microphonic. The last time I had tubes replaced on this amp was about 10 years ago, and they were brand new tubes so I didn't even think to check. I could buy all new tubes to compare, but that'd cost $150 for the tubes, plus $40 to my tech for the install, that's a lot of time and hassle just to find out if I should be returning these GE tubes, especially since I'm already out $260 for the tubes + $40 for the install/biasing. Thanks in advance for the help!
