Midwest P-5417-1 OPT
next, sine wave at 100 K Hz, no sec load, top is winding not connected, bottom is winding connected,
    109.4 KB
same thing at 1 M hz, phase shift actually gets worse at 1 M Hz with winding connected,
    94.9 KB
ok the following tests are conducted wit a 12 ohm resistor across the secondary, winding connected in bottom pic,
not much phase change at 10 K Hz
    121.3 KB
same test, at 100 K we get a substantial increase in amplitude with the mystery wind connected>
    129.1 KB
back to the sq wave with a 12 ohm sec load,
10 K not much difference,  leading edge comes up a little better but ripple added,
    103.4 KB
just for kicks we try a saw tooth wave, loaded sec, before and after winding connected>
    99.2 KB
one of the most dramatic changes in waveform was at the resonant frequency of 80 K Hz,
here is a before and after with loaded sec, sine wave.
this was just a test. had this been a real emergency, be advised to tune to radio station at 101.92 M hz, this is only a test.
    118 KB
