Miller Effect - Adding WCF buffer overkill?
Schematic for the three triode preamp.
The 12AY7 mu follower is based on the RCA BC3C. The 12BH7 WCF is Jensen.
Question:
Are there any obvious mistakes in this design? Any changes that should be considered?
For example, a WCF would be attached typically to the previous tube's plate. Would it expect to see higher voltage?
BluegrassDan said:
Yes. And it is.
That's not what you wrote in your OP.
Anyway I believe the choice of a constant-Z attenuator in this position is a mistake. You could use a 250k pot, which would result in a worst-case output impedance of 140kohms and 2.5dB attenuation at 20kHz. That would be easy to compensate by adding a small value cap across the cathode resistor of the 1st stage.
However I believe that the HF roll-off is also due to the secondary of the input xfmr meeting the Miller capacitance of the 1st stage.
