min resistor
kambo
CA
in general, what is the min  resistor i can use across the trx output...
(output connected to 600ohm line level)
ie: Gyraf's  SRPP-based version PEQ1A EQ... LL5402 output 2K2  ; pin 2-3
whats the min resistance i should keep there, so, i wouldnt damaging anything...
Why would something be damaged?
Most line-level gear can be run no-load no problem.
