scott2000
Awesome..... Thanks!
Do you have the power supply and Sat stage???? I think that's where the questions are??
yekuku said:EDIT : Unbelievable ! Scott2000 is right,
yekuku said:but on the unit they installed 1/4 watt, weird or what ?
yekuku said:They are R148 and R218 ( 82k & 100k respectively) and on the schematics they are rated 1 watt just like the others.
Do you think that the red resistors are rated 1 Watt ?
Dale pro ? Well you learn new things everyday ! No worries about the resistors , they are the right valuescott2000 said:Yes...Those are your tube's plate resistors I think...I'd have to look again but sounds right
I think those are Dale Pro resistors....very small package but rated high...The 2 watt ones look like regular half watt....
PR02000201003JR500, etc...
Hopefully you got the values right when you swapped them???sometimes the colors can be tricky if you go off off that thinking your values are skewed when measuring........ You pretty sure you got them right???
No worries about the schematics, I was just curious to see what they changed in the mk2 PSU.cyrano said:I'll need some time for the MKII schematics, I'm afraid. I was sure I had all Mindprint schematics in my repository, but they're not. I'll have to mine the archives.
There's something else that's weird. One of the schematics in that folder is for a Kemper Digital, but seems to have the same style and numbering as the Mindprint ones. Now, I've downloaded these in April 2010, so I can't remember what went on way back then.
Is there any relation between Mindprint and Kemper Digital? Both are German, but Mindprint ceased operations about a year ago. And now the domain kemper-digital.com redirects to kempermusic.com. Shifting again?
I am hesitating to do so because I am not so active in the forum and I dont want to be seen as a stranger that is bombarding the forum whenever he has a problem...scott2000 said:Maybe start another thread discussing this...... Just in case nobody checks this one out..... Make it catchy... like urgent! Transformer info needed...... or something......
May catch a big one.... ;D
gyraf said:I'm almost sure that this is NOT made as a step-up transformer, but rather a off-the-shelf standard 230:15V (or something like that, maybe 12V) transformer which's main property is the cost.
If it was custom-made, it would be MUCH cheaper to make it either as another winding on primatry trafo, or at very least as a mains transformer of its own.
So search for the cheapest possible transformer that will fit the pinout, and you're probably fine.
Jakob E.
yekuku said:Quick update:
I bought a generic 3VA 230V-15V trafo, and I tried to use it "backwards"
I fed 16V on the secondary, and I got 190 V on the primary.
Theoretically I should get near 240 V, I have no idea why this is happening. This also happened to the other trafos that I have tested previously...
