CroyTone Audio
Member
Hello, I have a couple of LA-610s (first version) in from a customer. the two units work great, but one unit is about 10db quieter than the other at the same settings. I checked voltages on the tubes and they were all pretty well matched in both units and I even swapped tubes between the units to see if it switched but it did not. The units are visually identical on the inside with no replaced parts or modding done to either. Any clue as to what may be causing the volume mismatch?
thanks!
thanks!
